22" stingray III's
22" stingray III's
Some people have asked for me to post up the weight of the 22" Stingray wheels when I recived them so here is the results.
22x9 Centerline Stingray III= 31lbs
Pirelli Scorpion Zero Asimmetrico 305/40-22= 40lbs
I don't think this is bad for a 22" wheel and tire combo of 71lbs! I hope to be able and run high 12's with them on. I haven't weighed the factory 17" wheel and tire but I think they should be close in weight. I broke my tranny after dropping them of to have mounted and balanced. Once I get the tranny back together from FLT I'll install my 2/4 drop, wheels and roll pan. Then I can post up some pics.
Originally Posted by Colby 04
My 17" escalade rims with 275/60/17 toyo's weigh 60lbs each.
My 20" Stingray III's with 275/45/20 Yoko's weigh in at 56lbs each
It's the same wheel/tire/drop combo that blue_04 is useing on his truck. I don't think it rubs. The tire is 31.5" tall, same as stock. Maybe he'll chime in on the rubbing issue.
By the way, I've actually put belltech spring spacers on my truck and now it sits perfectly level and doesn't rub at all.
Originally Posted by oneslammedgmc
Do you happen to know what your 20" wheels weighted before the tires were mounted?
They weigh under 20lbs. My bathroom scale doesn't register under 20lbs and I only got the rim to register one time when trying to hold it. They definately weigh 19lbs each
The UPS guy and the guy that mounted the tires commented on how light they were
