22" wheel offset for 4/6 drop
All that i have looked at are 9 1/2" wide, I like those Boss 313's they come with 40mm offset, some others only offer 18mm offset. Just need a little direction..
The above are close, and you might be able to get away with them, but add .5" backspacing to all of them and you shouldn't have to worry about clearance issues. For a 22x9.5, 6.5 backspacing would be close, probably have to roll the rear fender lips.
Check out this site, it tells you a lot of things such as backspacing/offset. http://www.rsracing.com/tech-wheel.html
go with the +40 or +20 offset. I have 20mm and they tuck but rub, but thats when I drop it down. I ran a 4/6 for a while and 20mm offset with no problems but I had to trim my fender lips
Im thinking about going with a Driv Moonshadow wheel that is 22x9.5 w/ 30mm offset and 6.5 back spacing. But do i have to stick with the 265-35-22 tire or can i go wider?
Lamartian92
09-10-2015 09:27 PM
Lamartian92
08-21-2015 01:43 PM
Codog
08-16-2015 08:23 PM
Porscharu914
08-10-2015 10:57 PM
