275/55/20 on stock height???
It was the inner fender well. Specifically the front part. I took a heat gun and heated it up and then stuffed a rag between in and the tire and that stretched it enough to not rub ever. We are talking 1/4 inch here.
I also have the 275-55 on a stock height 2wd truck (except for shackles in the rear) here is a pic. And yes they do rub some, mainly on the swaybar in extreme parking manuvers. The next time I get some tires, I will probably go with the 285-50, simply because I get alot of people asking "how does it do in the mud with them 20's?" Too many people think its a 4wd. It rides nice though... oh yeah, if you go with the 275-55's, def. get a 4.10. A 3.73 is still kind of a dog down low
12 Second Club
Thanx for the pics and extre info. I guess I will just mount a 275/55 on one wheel, and a 285/50 on on the other, and test fit.
Thanks for the offer on the tires, but I work for discount tire, and have that oh so kick *** employee discount.
Go with a 285/50/r20...If you have the money do the BFG G-Force. They have a nice tread pattern that will set off your truck. I have Eagle GTII's on there and I don't have any complaints except 1 blow out because of a defective tire. This pic is at stock height.
12 Second Club
See Im thinking the tire that is on jblack's truck, is what is making it look 4wd. Those goodyears have such a curve shoulder that it makes the tire look taller. If I go with a tire that has a more defined tread/sidewall breaking point, it may make it look better.
NOW!! If a 275/55 rubs, wouldn't the 285/50 do it more??
General ? Here.... ok so, when going to a bigger wheel/tire. the extra height gained in the wheel/tire is also applied to the body of the truck, correct?? Therefore, whatever overall inch I gain in tire height, will also raise the body an inch, or will it just take away an inch of the gap between the tire and body??
i just do not want to run a low profile tire, and make this truck look like ****, bcuz its all wheel, no tire, all gap.
275/55, 285/50.....decisons decsions, lol. And I'm still not dead set on which wheels, haha!!
12 Second Club
got to searching a bit, and found exactly what i want the truck to look like..
https://www.performancetrucks.net/fo...uot%3B+shackle
too bad its a 22" wheel with a 2" shackle drop. I assume its gonna take a 2/4 drop, with a totally different tire size to get this stance/look with a 20.
Guess i'll pimp the 4x4 look for a while, with a 275/55 or 285/50 and a 2" shackle drop.
Hell tho, i have to keep in mind i pull the a trailer loaded down with the LT1 and a 4 wheeler alot too, so I might run into problems with a 2" shackle drop....can't have a sport truck and tow rig in one I guess.
I got 99 Problems and a bitch ain't one
