5 Day Detail: Restoring a very hammered F350
FormerVendor
Time for the tires and undercarriage... a heavy dose of Super VRT on a pro tire app handled the rubber, invisible undercarriage spray turned the chalky fenders dark black
Time to unveil a little something I've been working on... but first the paint needed to be BARE. I wanted no residual polishing oils or anything on the surface so I wiped the paint down with isopropyl alcohol and a single soft towel.
You know that spray sealant I've been hinting at?? Well here it is... code-name Adam's Speed Sealant. We're still in testing phases, but its getting closer to being a finished product.
The product is unique in that its a high tech micro polymer that begins to form a very hard bond as soon as it hits the paint, for proper atomization it needs to be in a compressed aerosol can and will be the first product of its kind.
Its simply sprayed onto ANY surface (paint, glass, chrome, plastic trim, etc)
Then spread with a foam applicator, I prefer the Americana apps
Its an optically clear sealant, so it can be applied across decal edges without any buildup
After removing the residue with a double soft microfiber towel the sealant reveals a super reflective, bright shine. I moved the truck partially out into the light to inspect the results
The bumpers were also treated with the prototype sealant
FormerVendor
The entire truck was treated to a coating of the new sealant, including the glass. At which point I looked up to see the thermometer topping 103*.
Took a break and waited for the temps to get back into the low 90's... when they did I returned to the garage for a final coat of Americana Paste Wax double soft, snapped a couple of quick pics and tucked it in for the night before watching my Halos beat the Dodgers again.
Plan is to wake up tomorrow, pull it out, give it a final inspection, get some good full sun pics and hopefully by then the owner should be here to see it. I'm excited to see what he thinks
Some badass dropped Avalanche kept showing up in the reflections
I'll post the final shots tomorrow when I have a chance to upload them. Hope everyone has a good 4th of July! Thanks for looking.
DAY 5 - THE CONCLUSION:
Backed the beast out of the garage (no small task with the angle my garage sits) and gave it a visual inspection. Some spots were wiped down with Detail Spray and yet another clean Double Soft towel.
The windows were touched up with Glass Cleaner and Glass Towel to get some streaks that hadn't been visible in the garage.
A couple areas around the front tow hooks were hit again with In & Out Spray that I had missed earlier.
I even went so far as to polish the antenna that had been removed so I could clear the garage door before I put it back on.
Drove it down the street to a local park where I usually take my after shots. The lighting is good and theres room to get around the truck at various angles. Even at 9am the light was already harsh.
FormerVendor
Catching a reflection of the tree, the street light, part of the mirror and even the interior off the hood. Not too bad!!
Engine bay still looking pretty
Remember those dry, chalky, faded cowl pieces and mirrors?
The wheels, cleaned, polished, and sealed
The glass, now spot and streak free, with a coat of sealant
Trying to capture the lack of swirls proved a little difficult given the harshness of the light and the amount of metallic flake in the paint. A couple of these shots I tweaked the exposure slightly to show the condition of the paint - no swirls!
Sitting back at the house now, waiting for my cousin to come pick it up. Thanks for reading this marathon of a detail thread. Hope it was entertaining and educational... Now I'm gonna enjoy my last day of the 3 day weekend.
FormerVendor
If I were actually charging him... probably around $750 for the exterior work. This truck was farther gone than anything I'd normally take on, but since it was a gift for my cousin its different, the fact it was over 100* this weekend didn't help things.
WoW, amazing work as usual Dylan... i can only imagine how much more difficult it was to do ALL that work in the heat this past weekend, i'm gonna have to save up a couple dollars for one of ur details...
-Rob
-Rob
PT's Slowest Truck
Wow man, you never cease to amaze me with the way that you bring these vehicles back to life...this was definitely the biggest challenge that I've seen you post up for sure Looks like a completely different truck! You are a master, and the products that you use are definitely top notch!
Great work Adam. You love what you do and it shows.
(Anytime you're in MA, or coming to MA, let me know. I'd love to have my truck done by your expertise skills.)
