99-06 Trucks with 2/4 drops
I am trying to gather info from you guys with drops. I have lowered the rear of my truck almost 3" (2" shackle and overload removed.... I think it measures 3/4" thick or close to that) but my truck is not level at all. A matter of fact it still has a good rake to it regardless if I have my street wheels or drag wheels on. Well I want to drop the truck to a 2/4-3/4-5ish drop. I am planning on buying new GM front springs, because I think that my springs are 2"drops springs and the rear was never finished. But I am buying drop a-arms and a front spring hanger to go with the shackle. But here is the question.... do I need a c notch with a 4" rear drop or will I be just about on the bump stop? My truck will sometimes bottom out in the rear now if I have a bit of weight in it. And what would you guys recommend as the best riding lowered shock to go with. I have bilstein's shocks right now and it is a bit stiff. Rant over
Formerly ScreamingL
i was 3/4 and 2/4 i bottomed out only when had stock shocks, once i went with IAS shocks i never buttomed out
i swapped to rancho shocks and never bottomed out with this drop
i ran cut v6 springs for yrs up front
From what I've read from other people, they say the springs are "OK" but they would do the arms because it keeps the factory spring. So they say it " rides like stock" but are they any benefits to the springs over the spindles or a arms? Like weight reduction, handling... Etc? Also won't springs make it more of a "sportier" feel then stock springs with arms or spindles?
Fastest D1 Procharged Truck
the factory springs with drop arms will make the truck not handle good mine didn't rode like **** to
best setup is springs imo thats how i did mine 2 inch drop springs from belltech truck rides nice and also handles good
