advice for cleaning head/tail lights
The head/tail lights on my truck are a little bit oxidized. They aren't horrible, but they do have a slight haze on them. What would be the best way to go about cleaning them up? I've seen a few products at Autozone, but I'm not sure which one would be better. Also, are there any techniques I should try or avoid?
Thanks
-Jim
Thanks
-Jim
What i use is 2000 grit sand paper, plastx wax, and meguiars hi-tech yellow wax. Wet sand the lens, then apply the plastix, the the wax. When you wet sand it you'll see all that yellow crap come off.
3m has a headlight rejuvinator kit that you use with a drill. It comes with alot of different sanding discs and a polishing pad. I just saw them at Walmart. I think they were about 20 bucks.
I have hand sanded and then polished headlights before and the 3m kit seems like it would work alot easier.
just get a small buffing pad for your drill and some rubbing compound and got to town. unless it's really bad then you have to wet sand before you buff 2000 grit works good. Don't waste your time with waxes and "special" headlight cleaning kits.
ARC
57
02-21-2022 10:54 AM
Corvette454l88
09-01-2016 01:24 AM
gaps
09-02-2015 01:19 PM
