Anybody running stock TBSS wheels?
yup.
got some custom hub/wheel centric adapters from motorsport-tech.com out of Reno, NV.
took a while... 3 weeks or so... but custom is custom.
doubt I'm running 12 sec tho
only one I have is on the truck... inside the center cap hole you can see the lip they made for the wheel... then inside there it grew for the truck hub. They did great work on them.
I was too excited when they finally made it & forgot to snap one of just the adapters.
But they look very similar to these but silver & with 6 lugs. 14mm holes for the truck & 12mm studs for the wheels
Lots of guys run wheel spacers/adaptors on 3/4 ton and 1 ton trucks, so I wouldn't worry about them on a half ton truck. Just have to make sure you check the lugs on both wheel and hub to make sure they don't get loose on you. And being hub centric isn't neccessary, lug centric will work just fine with any conical seat aluminum wheels
Glad I finally found this thread. Been searching for some more info on this. I just ordered a 2/4 drop for my 01 RBSC silverado and was wanting to go with the 20" TBSS wheels with adapters but was a bit worried about them setting the wheels out too far. But that looks pretty good on yours! So now I guess I'm in the market for some tbss wheels.
lxcoupe
07-21-2015 02:12 AM
maxspeed05V
07-19-2015 07:08 PM
GMCtrk
07-17-2015 06:39 PM
