anyone w/ info on building fiberglass sub box
yea, heres a very vague description. build the wooden skeleton, wrap that with a t-shirt or some stretchable cloth really tight and staplr it to the box, put some fiberglass resin on it (many layers and especially where you know there will be alot of pressure), sand it (not too late because its a bitch and not too early because its still wet), cover some pits with bondo, sand again, paint
This is a really informative site: http://web.njit.edu/~cas1383/proj/main/
Hope it helps and good luck.
Baltimore Whore
do you mean build one with wood then glass it over.i have tried a way with just fiberglass.i took a big card board box then cut fit it in the place where the box would be.made sure that the edges were sealed off wit tape.then i filled that bitch up with foam.let the foam harden then take the cardboard off then just shave, form the foam to the shape you want.glass over it.it worked pretty good.i am prolly going to try this for my truck
GXPJAY
02-13-2022 08:15 AM
gtyler04
07-28-2015 06:21 PM
