Boze Wheels and M&H Drag Radials
#23
FormerVendor
Thanks, I kept second guessing myself on whether they would fit in the wheelwell or not. The wheels have taken over 8 weeks from start to finish on this first set. The fronts had to be sent out and narrowed down to 5" before the centers were welded in. Everything was compounded because of the size of the stock brakes (12.8" Rotors) and the clearance with the calipers. The valve stems are actually inside the wheels in the drop downs for tire mounting, we had to use flush valve stems for clearance. The tires are over 13.5" wide mounted on the rear wheels and 29 1/2" tall.
Front Brake Clearance
Flush Mount Valve Stems
Moving Parking Brake Cables
My Favorite Pictures
#27
[QUOTE=leftcoast32;3997868]Thanks, I kept second guessing myself on whether they would fit in the wheelwell or not. The wheels have taken over 8 weeks from start to finish on this first set. The fronts had to be sent out and narrowed down to 5" before the centers were welded in. Everything was compounded because of the size of the stock brakes (12.8" Rotors) and the clearance with the calipers. The valve stems are actually inside the wheels in the drop downs for tire mounting, we had to use flush valve stems for clearance. The tires are over 13.5" wide mounted on the rear wheels and 29 1/2" tall.
If you dont mind me asking. where did you get the Chevrolet brake sticker from?
GM1697
09-09-2015 01:52 PM
