Cal-vu mirrors??
Cal-vu mirrors??
does any one know if the silverado's are all wired for heated mirrors and the turn signals in them if you already have the power mirror package. Im going to order some and i would like those options, but im not going to order them with all that stuff if there are not going to work with the stock harness..
i dont think they are wired for heat or signals but i think calvu has a conversion setup for both
maybe someone else will chime in who actually knows ...might check out stylin concepts
Originally Posted by moes04silverado
yeah i just talked with stylin, they said the signal mirrors are a direct bolt up if you already have the power mirrors from the factory
Originally Posted by EDawg
they are direct bolt up. but they are not wired for heat or signals unless u have that now
well how can that be if the instrument cluster doesnt have a trans temp guage, but when you bolt in a aftermarket one or one that has the temp guage on it, it works??
Has anyone tried bolting on the mirrors with the glass turn signals that didnt have them stock? Stylin says the harness will work even if you dont have the turn signals on the stock mirrors; indicating that the wire harness is there, just not the hardware(mirror)
i have these on my truck and what i said before is not a guess, SO IF YOU DO NOT HAVE THOSE OPTIONS NOW YOU WILL HAVE TO WIRE FOR THEM!!!
