Candy Lenses
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
I did a write up about this a long ago(do a search). Same paint as the guys are saying, Testor's Transparent Candy Apple Red and Testor's clear coat.
Clean, then sand with some fine grit sandpaper.
Let dry. Repeat until desired darkness.
Sand, spray clear coat, let tack up for 5 minutes, spray another medium coat on.
Make sure each red coat dries completely. The drying is important.
Here are mine...
Here are mine...
1 Post
Some guy on FSC said he used the Testor's paint, then used some automotive clear. But when he sprayed that clear coat on, it got all wrinkled and messed up and he had to start all over again. So I don't know about the automotive clear.
Just use the Testor's paint and clear. No need to spend 25 for a quart of clear coat that will do the same job as the $3 can of clear will.
When you're done and it's all dry, get some fine grit wet sandpaper, get a spray bottle of water, and spray the tail lights as you lightly sand them. When you're done, polish and wax them and they will look
And it won't do the same job as the $3 can of testors clear, it will do a much better job
I do agree about wetsanding them when done to remove any trash that might have floated down in them.
1 Post
I've seen guys who spent $200 to get their tail lights totally painted red and clear coated professionally with automotive grade paint and clear. I spent less than $20 and there is no difference in the quality. I guess since people spend more money, they think it looks better, it's a psychological thing. But if you want to go ahead and spend more money than you need to, be my guest
Since the testors is hobbiest paint i don't see it holding up to the sun well at all, or anything like that. I don't know, guess i like the peace of mind of doing things how i feel is right
