Cant decide on 20s or 22s!
Ok well I just got off the phone with this guy at discount and I think he has no idea what he is talking about. I told him I wanted a tire that was about as tall as my factory tire which is a 245/75/16 to keep the same performance. I asked if the 275/45/20 was about it and he said that is 2 inches shorter than my stock tires. Then he suggested a 285/55/20 but that was still one inch shorter. I so confused right now.
Originally Posted by nightrunner
go with 275/55/R20 IMO, that is what comes on the Silverado SS
Originally Posted by BlackLM7
If you plan on only having a 2" drop in the back and keeping the front suspension stock, I would definitely go with 20's on 285/50-20 tires. Those tires are approx. 31" tall, which will fill the fender gap nicely and give you decent ride quality. If you plan in dropping the truck more in the future, I might consider 22's. Bigger wheels look better on dropped vehicles (especially when they tuck in the finder wells ), IMO.
265/75/R16 = 31.6" diameter 10.4" width 7.8" sidewall height
245/75/R16 = 30.5" diameter 9.6" width 7.2" sidewall height
275/45/R20 = 29.7" diameter 10.8" width 4.9" sidewall height
285/55/R20 = 32.3" diameter 11.2" wdith 6.2" sidewall height
275/55/R20 = 31.9" diameter 10.8" width 5.9" sidewall height
285/50/R20 = 31.2" diameter 11.2" width 5.6" sidewall height
Originally Posted by 03GMC
Im going with the 285/50/20.
I have 285-50-20 on a 2/4 Drop... On a 2" Shackle drop, I'd recommend a 275-55-20... A bit taller and narrower than the 285-50... Comes stock on all GMT-800 and 900... Will fill in the Fender Gap more...
Use this...VERY Helpful when researching tire size...
http://www.miata.net/garage/tirecalc.html
here is 285/50/20 with stock suspension. they fill the fenderwell pretty well on the front but mine sits higher in the back cause of the coil over shocks i have. i haul alot of stuff. just picture it lower in the back.
it actually looks better when i load it down. kinda levels out the truck but if i drop the back i'll end up dragging my pipes
