Clear Corners?
Clear Corners?
i know this i just common since of just poppnig them off but i wanted to make sure how can you get the fog lights off a 2000 chevy? im planning on getting some anyone know some that are the best im planning on gettin the diamond apc ones anyone have those thanks chris
You pull the 2 pins holding in the headlights, pull them out so you can reach the area behind the corner lens closest to the fender, then press on the clip and it will pop loose, then twist the light bulb connectors to remove the bulbs from the housing.
KINGCYCLES
10-02-2015 10:21 AM
creekrat
09-10-2015 12:59 AM
