color matched door handles
i have the part # for the tahoes carmine red door handles, but 72U is not my color of dark carmine red. i believe mine is 51U. so this won't work. anyone know if there is a part number for mine. i know it is not this:
Carmine Red / Redfire - 72U
15041755 Front LH
15041756 Front RH
15041755 Front LH
15041756 Front RH
Did they make the Tahoes or Yukons in your color red (with the 51U paint code)?
Easiest way to find out, is to find a SUV with the right color door handles and give the VIN number to a GM parts department. They should be able to tell you the correct p/n for the handles.
Hope that helped
Hope that helped
Easiest way to find out, is to find a SUV with the right color <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=5&k=door%20handles" onmouseover="window.status='door handles'; return true;" onmouseout="window.status=''; return true;">door handles</a> and give the VIN number to a GM parts department. They should be able to tell you the correct p/n for the handles.
Hope that helped
Hope that helped
Originally Posted by KeukaZ71
i've seen tahoes that have similar paint, but for some reason when i always see it, the tahoe looks a little lighter. i think the silverados are different
Other than that...have you checked other GM Trucks/SUVs to see if your color came in another vehicle? Maybe an Avy or Escalade?
Good luck
i'll try looking into that. thanks
Originally Posted by ILLNALI
yup, you can always pull the paint code and try to find a PPG dealer to get you some paint and spray some handles yourself
i still have paint left over from when i painted my bowtie. it is the exact color
