Color sanding
I am painting a set of mirror caps for my NNBS. I used GM aerosol paint so I knew it would match correctly. The finish is dull, not even close to the rest of the truck and the label says you can rub out with a mild polishing compound after 48 hours. It says NOTHING about applying a clear coat.
Should I:
Should I:
- Rub out, polish and wax and forget it?
- Color sand, rub out, polish, wax?
- Color sand, rub out, CLEARCOAT, color sand, rub out, polish, wax?
- CLEARCOAT, color sand, rub out, polish, wax?
- Other
Superman09
09-25-2015 05:55 AM
