Denali trans temp gauge problem
I bought a use Denali cluster with the trans temp gauge. Just my luck the trans temp gauge dose not move. Even if I turn the ignition on and off it doesn't twitch like all the others. I took the cluster apart to see if I could see a problem, but no luck.
Has anyone else have this problem or know what I can do to fix it. I was going to call US speed to see if it can be fixed or if I have to replace the temp gauge.
Thanks for any help
Thanks for any help
Cuz I AM a BADMOFO
Thanks for any help
Thanks for any help
Originally Posted by BADMOFO
I thought mine was broke too on my Escalade cluster when I first got it. I put it in during December (cold) and it never even read at all on the gauge, like it was below the lowest mark on it. As outside temps increased it started going up. What are the temperatures where you are at? If they aren't in the 40's or higher I wouldn't expect to see it do much. You should be able to drive it around a bit and at least see it creep up a tad. Or stall it up against the converter a few times and launch it and that should do it as well.
Go yank a tree out of the ground. It will move. Mine hardly moves to due to the e-fans, and cooler that I have. But when it get's to the 90's and up around here, it starts to show like you would think it would.
Originally Posted by gdelleney
would you want to sell the denali cluster, and if so how much?
Originally Posted by mzoomora
Mine doesnt move until about 20 min of driving on a 50 degree or so day. Rarely see it get very near the middle at all.
