Door adjustment
Door adjustment
Sup, My drivers side door on my Tahoe needs to pull in more. I'm getting wind noise, and the dreaded "door rattle" whenever I hit bumps. I've tried looseing the strike and pushing it over but it won't, also tried the latch on the door wtf? How the hell do you adjust that thing?
Naw man the door actually is popping out further than the back door, about 3/8s of an in.. Push the door a little bit and it looks and seals great? Any suggestions or other sites to try?
Thanx Jason
Thanx Jason
Originally Posted by -= MacADaYear =-
I have the same problem.... anyone?
Im ready to start yanking on my door cause the wind noise is driving me crazy!
Wind noise= bad
rattle=Real Bad
Not sure about a cure for your wind noise but that rattle in your door is most likely caused by loose bolts on the inner door. I've had the same problem. Remove your door panel and tighten those bolts back up and the rattle should go away. I have an article on how to remove the door panel up at my website.
