drag radial size????
hey i was looking at buying drag radials for my truck but idk what to go with 28 29 or 30 the truck has 4.10 and i prolly will use them on the street sometimes to what do u guys think
thanks
thanks
I would reccomend a bias over a radial. At your current power lever a DR will probably work well since you aren't going to be pushing it very hard. But if you plan to go much faster a radial will be dificult to make work especialy on a truck.
The 28 should be great. That is what I have on my truck and expect it to easily take me into the 11s next year. The shorter the better in most cases but with you haveing a 4.10, smaller will quickly cause you issues on the big end. A 28 mwill look good on the truck and should offer you a great final drive ratio.
Closer_2001
09-24-2015 09:15 PM
