Drag wheels/tires - Let's see them!
As the title says, let's see your track setups! I'm looking for a drag setup for my truck and can't decide on what I should go with. I thought about using a stock chevy 16 inch wheel and MT ET 28x11.50/16. I would like to drive to the track but the closest one is 1 & 1/2 hrs away so it would probably use too much tread driving that far. Would it be better to just swap tires out at the track? Thanks
Here's mine. I do drive to the track like that sometimes but its only 45 min away.......but on the drag setup I'm too low and drag more than the Vettes ![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
I'm running 255/50 16 MT ET Street radials on 16x8 Ultra wheels in the rear and 215/60's on the stock front wheels.
![](http://i10.photobucket.com/albums/a127/StrokerAce03/Truck/SDR1.jpg)
![Name: DSCF0030.jpg
Size: 143.9 KB](https://www.performancetrucks.net/forums/attachments/show-shine-discussion-129/147384d1502131792-drag-wheels-tires-lets-see-them-dscf0030.jpg)
![Name: DSCF0071.jpg
Size: 239.3 KB](https://www.performancetrucks.net/forums/attachments/show-shine-discussion-129/147385d1502131792-drag-wheels-tires-lets-see-them-dscf0071.jpg)
1 Post
im going with the same setup as StrokerAce.....but stock 16s in back with the MT et street radial 255/50r16 and my SSS 20's up front until i find some skinny 17s to clear my brakes and spindles.
