Drag wheels/tires - Let's see them!
Old 11-10-2013, 07:44 PM
  #131
Vortec350ss's Avatar
Originally Posted by fastjweb
The fronts are 16x8 with 4.5" backspace with 245/70/16s (I cut down the center caps to more of a flush look). The rears are 17X9 with a 5" backspace with M&H 390/40/17s. These M&Hs run small, and M&H said they would work fine on 9" rims. On some 17X12s I have the tread is about 14.3 inches wide,and the 17X9s they are about 13.0. They are not sticking out ridiculous either in my opinion, but I would like to bring them in some. I got the one new M&H for 150 bucks, so thats why im going to use them. The Racelines are $107 bucks a piece, and are 20.3 pounds on the bathroom scale. They will work for now anyways.
Now we're talkin!! I love that tire set up. I'd love to run those in the rear just for a real aggressive look even if I didn't need it with AWD. Problem would be perfectly matching the front tire diameter
Old 01-24-2016, 01:20 AM
  #132
october7646's Avatar
so many small tires
Old 05-13-2017, 06:05 PM
  #133
Registered User
kevin neyda's Avatar
Default What brakes are running on the back
Originally Posted by 2doorfury
Wheels are cragar soft 8's 15x10 in back 16x7 up front. Tire is a 275/60/15 out back.
I want to put the same wheels 15x10 on my truck but I don't know if they will fit with the OEM disc brakes what kind of brakes are you running ?
Old 05-20-2017, 08:46 AM
  #134
ironcityboom's Avatar
Pretty sure he was running a stock drum setup. Im on the same wheel and tire setup and I'm on drums as well. There's a bunch of write ups about converting to a disk brakes that will fit 15" wheels just look around using the search function..
Old 05-26-2017, 11:03 PM
  #135
gammey4's Avatar
17x7's and 15x10's before I lowered the front another 1.5".
Attached Thumbnails Drag wheels/tires - Let's see them!-photo176.jpg
Old 05-27-2017, 08:44 AM
  #136
USMCvet0311's Avatar
What tire you running in the front?
Old 05-27-2017, 08:49 AM
  #137
gammey4's Avatar
Originally Posted by usmcvet0311
what tire you running in the front?
225/60/17
Old 07-19-2017, 08:32 PM
  #138
2004silvy's Avatar
Rears are cragar soft 8 15x8 with Mickey Thompson 275/60/15.
Fronts are 17x7 with a 225/65/17 tire. Wheel only weighs 19#. Any guesses on what these are from??
Old 07-20-2017, 05:54 AM
  #139
fordbug77's Avatar
Spare wheel on some truck and SUV.
I also have 4 for sale.
Old 07-20-2017, 09:27 AM
  #140
2004silvy's Avatar
you win! I haven't really determined what trim level they came on though. BTW did yours take a ton of weight to balance? Mine did. BTW what are you asking for a whole set. I don't need anymore but was just curious on what these are going for.
Quick Reply: Drag wheels/tires - Let's see them!
