Drag wheels/tires - Let's see them!
#142
#144
Working on mocking up my set. Going with factory 17s in front and 15x10s 6.5 backspace in the rear. Planning on running a 295 65 15 dr. wheels need cleaned up and paint or powercoat. Havent decided on color yet.
#146
It is a bloton 4 link. It is a partial ridetech airbar 4 link setup, originaly for air springs. I contacted ridetech and purchased only the parts and pieces I needed from one of their kits so I could run a coilover suspension. I have a different set of springs (red) still to put on, and a Tahoe rear sway bar im going to try to use, if I can find a way to make it fit and clear my true dual exhaust. Also have ridetech stuff up front.
#148
I have not had it at the track yet. I was having bad wheel hop issues, that's why I decided to switch to a 4 link. Plus the ride quality with coilovers is night a day compared to lowered on leafs. I had caltracs on with the leaf springs before with relocated shocks the ride was pretty rough. Going with some bigger tires for traction on the street. Got my wheels painted, I think they turned out pretty good for a cheap set of steelies
#149
That budget drag pack is looking great! I almost went with the same fronts but they were somewhat heavy so I ended up with those 7 spoke spares in my pic. Just curious what was your setup like whenever you were having the wheel hop issues. Granted my truck doesn't make alot of power but I've experienced 0 wheel hop in it. Mine either dead hooks or spins. Mostly 1.80 60s but have been 1.7 s as well.
#150
Wheel hop may have been a combination of a few things, from street tires, to crappy DJM rear flip kit. I have zero issues now. Here is how the truck looks on the budget drag setup.
17in stock fronts on a 275/60/17 and 15in rears on a 295/65/15
