Educate me about clay bar...
#41
Thanks! I've heard good and bad about that buffer...I'm not sure you can do much correction work with it.
I've not used Zaino paint products, but I have seen the results...stunning. The thing to keep in mind is that you're doing very little correction with their products. Instead, they're designed to fill and hide the imperfections. What makes Zaino so much better than similar products (i.e. Adam's) is the durability of the sealant. Those swirls stay filled for a pretty long time, and the finish stays wet and reflective. From what I understand, it's not difficult to use their products, but you do need to do so in the right order and make sure the finish is very clean beforehand so the products can bond properly.
The great thing about the entire Poorboy's line is that their stuff is very easy to use. It doesn't always offer the greatest results - at least compared to some other brands out there - but it's particularly great for folks just getting into the whole detailing thing.
#44
I checked out Zaino's and Poorboy's websites last night and did some reading, Zaino seems like it's alot of work, but good results. I like the looks of the Poorboy's stuff that has polish and wax combined...perfect for a lazy butt like myself lol.
Saw a buffer on Harbor Freight's website for $20...made by Chicago or something like that...
Your hood looks awesome Vroom Vroom![Mr. Cool](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cool.gif)
Remember, improperly used the rotary can do more harm than good. Start out using light cut polishes and pads and you will be all set.
#45
The Harbor Freight buffer can do alot of correction. The main difference between the HF and a $200 buffer is overall build quality and the ability to hold rpm with a load. If you are only planning on using it occassionally it can help you out immenssly.
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
They're may be an "Educate me on buffing techniques" thread in my future
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
#46
I spent four years with the PC before buying a rotary. For most of the details I do the PC is fine (with 4" pads and polishes with good working time it is amazing what correction you can do with a PC), but the rotary does the work much faster. Definitely good advice on being very cautious with the rotary until you gain confidence on it.
Anyway, my apologies for helping take this thread off-topic.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
#48
just a little quick over view of what i do. most cars or trucks that i encounter are a little more than marred and swirled, so i often bring out the big guns. after claying, i will bring out the makita and 3m perfect it running compound and a cut pad(only if it calls for it), then i will correct rotary mistakes with an orange pad and porter cable with menzerna intense(an extra step but well worth the time). i then finish with a white pad on the makita and menzerna final polish II. this FINALIZES everything, really adds depth and perfection. Menzerna runs about a dollar and ounce, but if you are using strictly on your own truck, it should last forever. final polish is a little more, but a crucial step. if you really want a close to perfect shine with little effort and no chance for damage, get a PC, its about $130. here are some shots
here are a couple of my truck:
![](http://i111.photobucket.com/albums/n150/jburks3/Picture052.jpg)
![](http://i111.photobucket.com/albums/n150/jburks3/Picture047.jpg)
here is a customer car from the other week:
![](http://i111.photobucket.com/albums/n150/jburks3/sl10.jpg)
![](http://i111.photobucket.com/albums/n150/jburks3/sl8.jpg)
![](http://i111.photobucket.com/albums/n150/jburks3/sl20.jpg)
#49
I've got the PC and a Makita too...our approaches are nearly identical, although I'm starting to use the rotary more and more for all correction work - it's just so darn fast.
FYI, in case you haven't encountered this, the carriers/fillers in IP have been known to hide as many holograms as they correct. It's not something that's caught until a wash or two. I'm starting to use a quick alcohol rub after polishing, followed by a walkaround in bright sunlight or via halogens to make sure everything is just right.
