Escalade cluster?
Originally Posted by wes00silverado
Where do you get the LED replacement lights for behind the cluster? I cant seem to find them anywhere. Do you just take out the 194's and plug in the LEDs or what?
Originally Posted by 99Silver5.3
The stock bulbs are actually soldered into the sockets. I ended up breaking one when I tried prying the bulbs out. So I did a search for the 194 twist lock sockets on the net. Ended up buying 6 of the twist sockets from a vending machine company in Cali for .59 cents a pop and they worked perfect with my LED's. The lights you can buy at www.superbrightleds.com.
Come again? Which ones did you use?
Thanks for the info. Yeah I changed the lights behind the dash to regular green bulbs and broke two of the twist things in the process. My dad drives a Kenworth and surprisingly he had the twist things in his dash and could change out the bulbs so I took his I'll probly get on and order some here in the next few days.
Just to make sure I am getting the right thing, for my cluster I would need the Single LED Wedge Base Bulbs right? It says that they will replace the 194 bulbs so I know they are the right size. If that is what I need how to I install them? Do they just plug in the regular bulbs or do I have to wire them up?
Instrument Cluster and Gauge Backlights
Twist-Lock type instrument LED bulbs consist of a T 1 1/2 (#73/74) miniature LED bulb installed in a twist-lock socket base. LEDs have a wide viewing angle.Available with White Blue Green Red or Amber LED
Overall length: 21mm Extends into cluster: 14mm
#74 LED bulbs are also available without the holder
Would these not work instead of having to buy the socket and LED bulb seperately?
I dont think those will fit in the socket holes on the cluster. They look too small to me.
I bought 6 of the white 4-LED bulbs from SuperBrightLEDs.com. I got the new bulb sockets from Bay Area Amusment. Sockets
