Finally got my decals
So, I got my liduidome bow tie, front bow tie over lay and reflector over lays. The rear liquidome bow tie looks really nice. It was pretty easy to install, with some patience though. The front over lay was a little more difficult, because if not laid down exactly right, it looks really sloppy, so close isn't good enough. Lastly, the reflector over lays. Well, I scrapped mine. The vinyl is extremely thin and difficult to work with. If there was one thing the directions should have said that didn't, it's REMOVE THE REFLECTORS FIRST!!! Putting those things on without removing the reflectors can be a nightmare. I didn't even get the first one on before it was stretched out too much. Simply holing it into place was causing me to stretch it accidentally. Had the reflectors been laying flat, lining it up would have been cake.
I took some pics, but too bad the lighting stinks. I re-took a pic of the front and rear again in the garage so you can see it. I also took off the "Trailblazer" emblems. if you look closely, you can see a part of the vinyl that tore in the lower right corner. I was simply rubbing it down when it tore. I am telling you, these things are thin. BTW, I somehow managed to get a bubble in the rear bow tie too. It's right in the middle. I am hoping it works itself out because I was not taking a chance of taking it back off.
Where at in pa are you from?
"The message you have entered is too short. Please lengthen your message to at least 5 characters."
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
