Finished the drop on the 4x4
Old 06-04-2011 | 11:54 AM
cdub81's Avatar
Default Finished the drop on the 4x4
I dropped my ccsb 4x4 a few months back. I did a flip kit and spindles and 2500 keys up front. The back was way too low and had some cali lean for sure so i finally got around to installing the lift hanger's on the rear. Just a few crappy cell pics
BEFORE:
AFTER:
Next thing I need to get is a high speed balanced driveshaft from driveshaft specialist in san antonio, I was quoted $640 with a new slip yolk (nickel plated). The current one rubbed on the crossmember and m made a good groove in it, also need to fix the damn pinion seal leak!
Old 06-04-2011 | 02:01 PM
Spoolin's Avatar
GFYS and STFU
Looks great!! I love to look of dropped 4x4's!
Old 06-04-2011 | 03:08 PM
SlowTruk's Avatar
Looks good man. I also have the huge aluminum ds that ate into the crossmember. I raised the truck back up an inch all around and it doesn't scrape anymore, but I want a new ds
Old 06-04-2011 | 06:02 PM
Beatdown Z's Avatar
Laid Back
Looks badass! One would never guess it's a 4wd truck.
Old 06-05-2011 | 07:06 AM
cdub81's Avatar
Thank you sir!
Yea I'm not sure if the stock one is a 5" shaft but that's the one I'm going with from driveshaft specialist. I would do a 2 piece shaft but i dont have the fabbing skills for the crossmember...
Thanks man, The only way you might be able too tell is if you look dead staright at the front you can see the skid plates as i haven't removed them yet!
Old 06-05-2011 | 11:01 AM
Static54's Avatar
Looks great. I left my skid plates on, ya mine as well if you're lowered.
Old 06-05-2011 | 11:37 AM
06Sierra2's Avatar
looks great, makes me really wanna drop my crew.
Old 06-05-2011 | 11:56 AM
black00chev's Avatar
Slowest turbo build ever!
Looks really good! Ill just be happy to have mine another 2" lower let alone like that!
XL7
05-05-2022 01:48 PM
gbbmk
09-29-2015 10:19 AM
superchomper2003
08-26-2015 09:39 AM
KyleW707
07-29-2015 08:17 AM
vmaxpro
07-17-2015 07:24 AM
Quick Reply: Finished the drop on the 4x4
