fog light mod (i tried searching)
i cant figure out how to make so just my foglights can be on without the headlights on, or i can keep them on with the high beams
do u have a dome over ride button???
if so, push it in and out 4 times...should cut the DRL and low/high beams off but will still be able to use fogs.....
i think
i think
on the 99 and maybe the 00 the dome overide does not work, the only thing i know to do is before you crank it but the e-brake on one click then crank it. the lights will be off then when you want to turn them on release the e brake.
mine is a 02 and i have to press the dome light 4 times and then it cuts my lights off and then turn the fog lights on.. then if you want the lights back on just push the dome 4 more times and they come back...
Corvette454l88
09-01-2016 01:24 AM
markyrgv
08-16-2015 11:50 PM
RoidedSS
08-11-2015 11:51 AM
