Fullsize GM wheel compatibility?
Old 12-12-2009, 10:29 PM
Snappy's Avatar
Default Fullsize GM wheel compatibility?
Are all 6 lug GM full size (Silverado, Tahoe, Avalanche, Suburban) wheels compatible between years? Specifically, I want to know if the 07-09 or 04-06 wheels will fit on a 99-03 Silverado.
I've searched and searched but can't find an answer, although it seems to be yes. I know the newer trucks require 17's for clearance (found that out in searching). If Mustang wheels fit a Grand Prix, I'd expect the Silverado wheels with the same backspacing and bolt pattern to be interchangeable. I've read that GM came up with some new fangled design that made other wheels not work with the 99+ trucks, so I just wanted to make sure I checked before I bought a really cheap set of wheels. Guys buy big wheels all the time, so the stockers are dirt cheap.
I just leveled my truck with the 2" spacer in the front and was thinking about getting 17's and 30" tires.
Old 12-12-2009, 10:37 PM
charcoal03silvy's Avatar
They will fit.
Old 12-12-2009, 10:41 PM
13 Second Truck Club
DV2000NJ's Avatar
Yup, all of the 6-lug wheels from the full size vehicles will fit (Trailblazer/Colorado 6-lug wheels, however, will not).
Old 12-12-2009, 10:44 PM
Wish the TBSS wheels would fit the trucks
Old 12-13-2009, 02:17 AM
PT's Slowest Truck
budhayes3's Avatar
There are other manufacturer's wheels that will fit also...the Nissan Titan wheels come to mind (one of my personal favorites )
Old 12-13-2009, 03:49 AM
ScreaminChevy's Avatar
except 99-03 16" wheels will not fit 04 up cause of bigger brakes
Old 12-13-2009, 10:13 AM
jhe2003's Avatar
05' and up I have an 04 with 16"s
Old 12-13-2009, 10:20 AM
DV2000NJ's Avatar
I believe Toyota wheels will also fit, but I'm not positive. The lug pattern is the same, but the center bore might be different. I know GM wheels will fit on a Toyota, though.
Old 12-13-2009, 12:05 PM
PT's Slowest Truck
budhayes3's Avatar
Almost forgot about Toyota, although they may have a different backspacing...
Old 12-13-2009, 12:08 PM
onebad03's Avatar
i dont know about all toyotas but i know 4-runners will. i had to put an extra 4-runner wheel on a truck to move it into the shop.
Quick Reply: Fullsize GM wheel compatibility?
