Getting closer to painting the hood
Old 07-06-2008, 09:04 PM
  #91
SPAM HUNTER
2005 Silverado's Avatar
Wet sanding will clean up the little stuff thats left. IMO your paint job might end up with less orange peel than the factory How does the color compare to the truck?
Dustin
Old 07-06-2008, 09:12 PM
  #92
KySilverado's Avatar
Dustin
Keeping my fingers crossed. I know wet sanding will do wonders. The match is close. Won't really be able to tell how close until I put it on the truck. Before starting it wasn't a perfect match from the body shop. If its as good as the other things I've painted with paint from Automotive Touchup it will be perfect.
Old 07-06-2008, 09:16 PM
  #93
SPAM HUNTER
I know i have faith.
Dustin
Old 07-06-2008, 10:34 PM
  #94
Frito Bandito's Avatar
That looks really good, especially for your first time. Painting is something I've been wanting to pick up as well.
What grit paper are you going to use when you wetsand? I would go with Meguiars Unigrit and one of their flexible sanding blocks. I've used 3m sandpaper before and I've been left with tracers much deeper than their rated grit. Even when keeping the sandpaper lubricated, flushing it often and changing sheets a lot...... Since you have a Porter Cable DA I would finish with 3000 grit so the sanding marks will be easy to remove. Just a suggestion......
Can't wait to see the finished product!
Old 07-07-2008, 05:19 AM
  #95
11 Second Truck Club
Breeze's Avatar
It looks awsome Roger job well done.
Old 07-07-2008, 08:01 AM
  #96
Thanks for the kind comment.
Was planning on wet sanding the clear with 2000 but you are right the orbital with foam pads make for a lot of buffing. I'll pick up some 3000 and try it.
I am curious as to how I got such deep scratches in the primer. I guess I let the paper get to loaded. Lesson learned.
Old 07-07-2008, 08:02 AM
  #97
Thank you sir. It looks okay. A real body paint guy would laugh at it.
Old 07-07-2008, 02:15 PM
  #98
Got the garage cleaned up and things back in place. Got the hood in its spot for the sanding and buffing. The more I look at it the more confident I am that I will be able to make it slick.
I did screw up and not go around the bottom edges real well. My solution is to mask it up and go around the very edge with some of my spray can color and clear.
Old 07-07-2008, 03:24 PM
  #99
shakesvho's Avatar
i been following this thread and for your first time at this you are doing great, I enjoy reading all your threads, keep up the good work
Old 07-07-2008, 03:33 PM
  #100
Piss Pumps for Sale
Chevy Cowboy's Avatar
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
I think its one of the best do it youself paint jobs I ever seen, especially for a first time attempt, I couldnt have done 1/4 aswell, looks great!!
Quick Reply: Getting closer to painting the hood
