Getting closer to painting the hood
Same color. I'd like to do a ghost SS style stripe but beyond my skills.
Harley dudes don't scare my wife They run from her!
Resident Retard
Taking it down to metal. The bubbles pulled clear down to whatever primer they used to paint so I figure the offending contaminant is in it. I'm using a 2k Urethane primer. I hadn't planned on block sanding but I'm thinking about doing it now. I don't have any block sanders so I'll have to find some.
http://www.eastwoodco.com/shopping/p...anding%2Cblock
Also since your taking it down to bare metal you need to seal the paint, an etching primer will work, just make sure it is compatable with urethane that your going to shoot....
IMO I would practice on some scrap you have laying around, make sure to keep the pressure down and the paint wet on the panel, to preven dry spraying...
This is the type that I used for primer and clear coat sanding at the body shop I used to worked at.... I used the old school method of paint sticks for large flat sections, when they get wet they are more flexible... Just make sure you sand in different directions...
I wish I had some panels to practice on. I don't. I did plan on spraying a few swipes on some cardboard or something to adjust the gun and such.
Yeah. I'm in way over my head
