Guage install. Looks sweet!!
Here is a nite shot. I have a blue bulb in but it looks green. I need to find a bulb that will be blue. The guages have a blue or green option. This pic was on green but looks blue.
I got the idear from 01 Thunder who did his. I used colored speaker wire to run to tranny. Install the electrial sensor on the drivers side and ground on tranny bolt and also ran wiring thru plastic harness. I tapped in to a 12 volt source in fuse block inside cab. Tapped on to the green wire on back of light switch so it will dimm with others. The trick is getting the guage in the cluster. I took my time doing it and had a problem and 01 Thunder helped me figure out what I had done wrong. I wish I had taken pic but didn't have a ditial camera. I do now. I could pull it out and shoot some pic to give you an idea on install. What ever you do take your time. Here is a tranny shot.
wrb002
08-25-2015 03:56 PM
