Guys with the three piece engine covers....come on in!!!!
Old 01-17-2006, 02:26 PM
slowprocess's Avatar
Originally Posted by Scream
I was a dumbass and sold mine. I was planning on swapping to the car intake, but after seeing how it's running now I don't think I'll need to do it.
Not to hijack my own damn thread.....but what did you do differently from the dyno to the track? I'm guessing it was the addition of the spray to make all of that high end hp....
SSlow 4.8's Avatar
ohhh... i have a stock one but its painted red if you want it, lol you probably wanna sand that down pretty good... its rattle can and no prep
i never realized you were running a 5.7.. i thought u were running those n/a low 12's on a 5.3 motor lol.
Old 01-17-2006, 02:29 PM
Scream.....for the first time in a while you've given me some hope. Your 1/8th trap was higher than mine, so you're 1/4 will no doubt better, but I did get a 7.40 the last 1/8 track I went to. Maybe there is hope for me and mid 11s
Old 01-17-2006, 02:47 PM
MOOBIES Moderator
Scream's Avatar
SSlow 4.8: the best b/f this weekend was only a 13.9 @ 101. I picked up quite a bit with the little 100 shot!
Slow...Here's a quick list of what mods I have done to the truck at Speedfab before the 11.5 run:
  • 4L80E swap w/ Yank 3200-stall converter and Transgo HD shift kit
  • 4" aluminum 3/4 ton G-van driveshaft
  • NX MAF kit (100 shot)
  • 4.11 gears, Eaton posi, T/A girdle
  • Cal Trac traction bars
  • Pacesetter LT's
  • dual 3" exhaust
The Pacesetters were put on before it went to the shop, but I didn't have any 1/4 numbers.
Here's a before/after comparison of my timeslips from the first time I ran w/ the LS1 swap, to my best motor pass and nitrous pass from this past weekend:
TIME----R/T----60'----330'----660'----MPH----1000----1320'----MPH
11:27---0.239---2.306---6.057--9.091--81.08--11.697--13.917--100.99
2:12---0.163---2.072---5.716---8.618---84.91---11.091--13.190---107.42
3:44---0.086---1.751---4.860---7.447---94.22---9.682---11.578---118.98
I can only guess that the dual 3" exhaust lost me some low-end torque but allows the motor to breathe really well up top. I don't care, it sounds WICKED!
Old 01-17-2006, 02:56 PM
  • Pacesetter LT's
  • dual 3" exhaust
TIME---R/T---60'---330'---660'---MPH---1000---1320'---MPH
11:27----0.239----2.306----6.057----9.091----81.08----11.697----13.917----100.99
TIME R/T 60' 330' 660' MPH 1000 1320' MPH
2:12 0.163 2.072 5.716 8.618 84.91 11.091 13.190 107.42
3:44 0.086 1.751 4.860 7.447 94.22 9.682 11.578 118.98
Looks like I'm going to definately have to address my 60ft times. When I was running the truck all motor...I was cutting anywhere from a 1.72-1.90 60ft.
On my last/best 1/8th my 60ft was a 1.96(or something close to that) and it went 7.40@92.???mph. I had to increase the window switch ON pill from a 3000 to a 3400, and still got some wheel spin. I just wish I could launch off the spray one good time and have it stick. I think the time would be very decent.
Old 01-17-2006, 03:04 PM
SSlow 4.8's Avatar
oh sry... broke into the 13's is what i meant.
Old 01-17-2006, 03:58 PM
04BlackSilverado's Avatar
I had the same issues when I put the Escalade covers on my 5.3, you can see where its hitting. I would like to see if the Escalade or SS tube is different also. Yeah its dirty too......
Old 01-18-2006, 04:04 PM
kdirectorate's Avatar
I have a set I'm not using. I wish I was though... I had trouble getting them on. I think that I need to remove my EGR valve first, ...and I'm not really up for doing a CPU tune. So let me know. It's brand new and I would like to recover some of the money I dropped on them. The center piece has the 6000 on it.
Old 01-20-2006, 11:01 PM
SnakeOiler's Avatar
That's the way mine looks, but there is actually a 1/4 inch gap between the tube and the cover - they don't touch.
Old 07-26-2007, 09:08 AM
tb8100's Avatar
How does the fill neck come off? Is it just screwed in there? I'm worried I'll snap it off! Mine won't clear the cover either-
Quick Reply: Guys with the three piece engine covers....come on in!!!!
