HAL/QA1 shocks part #
14 Second Truck Club
lookin for the shock that will fit our truck... have found numbers.. but nothing specific...
here is what i have found.. does anyone know if these are right?...
DR/UR/ALN-5855 or DR/UR-7855-9855
i'm thinking its the 5855 pn. it seems to be the most common.
it's a custom job, They don't make stock replacement shocks for our trucks.
Here's my older post;
https://ls1tech.com/forums/showthrea...ght=qa1+shocks
I havn't put them on the front of the truck yet But I'm sure they make a lenght that is compatible.
I went with bilsteins up front because it would be a pain in the *** to adjust them up front with out having a long pair of plyers to sneak through the coil spring.
I think Amy with the white truck used them up front maybe she'll chime in.
thats a good write up creed.... but unfortunately none of the pictures showed up... i really want to get these HAL's... i would settle for the edelbrocks though...
http://www.ridetech.com/productinfo/shocks.asp
Don't know if the prices are competitive, I doubt they are, but at least you can see some of the shocks they use on the GM kits.
Qa1 wasn't really any help,
I gave them a lenght I was looking for and thats what I got.
There the stocker star series.
If you get the part # I gave you I can help you through what washers/sleeves you need via pm or email to make them work.
As for the front I would get eldebrocks or something similiar. You won't be disapointed.
heres the picture again
