HID thread
Old 03-05-2009, 11:09 PM
  #41
Parke10's Avatar
Originally Posted by 1989k1500
You shove them into the connector next to the pin, then when you plug them in it tightens up.
Originally Posted by skyhighsami
When you say wedged them in there do you mean the resistors or do you need to connect the resistors into the wiring
i didnt unplug mine or remove the BCM or anything just droped the kick panel cover, took the little leads that are on the resistor, and some needle nose pliers and wedged the wires in the back of the plug next to the stock wire and they just fit in there pretty snug like, then i made sure the leads from either resistor were touching each other, if ud like i can take come pictures this weekend.
Old 03-06-2009, 09:49 AM
  #42
no title here
skyhighsami's Avatar
I would love some pictures. The truck will be coming apart and I would like to have all the info to do the mods I want all at the same time
Old 03-07-2009, 12:54 AM
  #43
Parke10's Avatar
i will try to get them by tomorrow afternoon
Old 03-10-2009, 11:03 PM
  #44
01burban's Avatar
Originally Posted by Naranjas HD
truck in the middle how are high and low and fogs on ????? at same time ?
Old 03-10-2009, 11:15 PM
  #45
1989k1500's Avatar
relays. do the 4 hi mod and then do the same but to the fogs.
Old 03-11-2009, 09:00 PM
  #46
baron's Avatar
I think if you put the resistors in the right way the highs will make the lows come on, and whenever the lows are on the fogs are on.
Or you'll have to jump from high to low and high to fog. Then when your highs come in so do your fogs and lows.
Heres how to do it with the highs making the lows and fogs come on. This is the gray connector on the BCM.
If you go from highs to lows, and lows to fogs, it will do what you want with the fogs being auto with the lows. Put the resistors in the bcm and give it a shot, if it doesnt work right, turn the resistors around.
will this work on my 99?
Old 03-12-2009, 12:37 AM
  #47
Parke10's Avatar
no the 99 is a wire mod, the 03maybe 04 cant remember to like 07 classis are done the way shown above
Old 03-12-2009, 12:44 AM
  #48
baron's Avatar
can you point me in the direction on how to do the wire mod?
Old 03-12-2009, 09:17 AM
  #49
Parke10's Avatar
i cant seem to find it, tho i may be using the wrong search terms, im sure someone else will chime in and find it, im pretty sure it was just cutting and grounding a wire..but i cant remember for sure.
Old 03-12-2009, 08:56 PM
  #50
baron's Avatar
anyone find it yet?
Quick Reply: HID thread
