View Poll Results: Which Hood
Voters: 108. You may not vote on this poll
Which Hood do you like the best?
#41
Originally Posted by 1SlowHoe
You dont see the stick on scoops very often either, You should get these. FOR REAL!
Then nobody will break into your truck. They will know you are a tasteless ******* for putting those on your hood and figure there is probably nothing good in your truck to steal.
I say cowl or HD.
#45
Originally Posted by nightrunner
wouldnt the HD and cowl be about the same height?
wait does the cowl even give you additional under hood clearance?
#46
Mr. Obvious
If I have to go with a cowl hood Im going with a functional one not the ones most go with on here that are strictly for looks
i wouldnt go with anything but steel. i dont think i even know of anykind of 2" cowl with extra underhood clearance.
when most say the cowl is functional they mean functional as in extra airflow, right?
#47
Cuz I AM a BADMOFO
I would bet that the HD hood has as much room under it as one of those aftermarket cowl hoods, but I'm not positive. I'll look at it later tonight and try to get a pic of it posted up.
#48
get the cowl hood with the vacuum operated intake door flap thingy!! i remember seeing that hood put on a truck one sunday on TRUCKS! and always thought that hood was bad ***!
#49
Bad, can you measure from the top of your engine cover to the bottom of the hood so I can get an idea if it will work.
#50
Cuz I AM a BADMOFO
