how can i go lower.... i am 4x4
Old 08-14-2008, 06:00 PM
jimbob1's Avatar
Default how can i go lower.... i am 4x4
i want to go lower. i am thinking like maybe 3 inches lower.
any suggestions?
since i am 4x4 do i have different rear springs?
i dont want to break the bank
thanks
Old 08-14-2008, 06:12 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Remove the rear blocks and get lowering spindles for a 2/2. Add lowering shackles and de-twist the torsions for a 3/4. Click on my sig.
Old 08-14-2008, 06:19 PM
jimbob1's Avatar
i have already uncranked the t-bars and taken out the 2in block and done 2in lowering shackles. i want more
Old 08-14-2008, 06:27 PM
trever1t's Avatar
Spindles and hangars, you'll want to C'notch.
Old 08-14-2008, 07:06 PM
jimbob1's Avatar
any other ideas?
Old 08-14-2008, 07:51 PM
BlackPearlZ71's Avatar
Originally Posted by jimbob1
any other ideas?
LIFT IT!!!! 4x4s are meant to be up in the air, not low to the ground..
Old 08-14-2008, 08:50 PM
jimbob1's Avatar
well if i lift i will go slow it i lower it i can go fast!
Old 08-14-2008, 08:53 PM
trever1t's Avatar
there aren't that many options ya know? you can swap LCA's and Spindles up front, blocks, shackles, hangars or even take out leafs in the rear.
Old 08-14-2008, 08:54 PM
you can get drop keys, spindles or arms for the front keys can get you 2-3" arms 3" spindles 2" out back add hangers for another 2" or stock shackles back in with a flipkit will get you 6" but any more than 4" out back you'll want to notch it.
Old 08-14-2008, 09:57 PM
thats why 2wd's were invented bro.. dropped or stock height, a 4x4 is still going to be heavier than a 2wd at same stance, therefore going to be slower no matter what.. since they're going to be slower no matter what comparing it to a 2wd with same mods, **** might as well keep it stock height or higher, wat 4x4's were meant for.
Quick Reply: how can i go lower.... i am 4x4
