how can i go lower.... i am 4x4
do yall know if there is any difference between 2wd and 4x4 rear springs?
thats why 2wd's were invented bro.. dropped or stock height, a 4x4 is still going to be heavier than a 2wd at same stance, therefore going to be slower no matter what.. since they're going to be slower no matter what comparing it to a 2wd with same mods, **** might as well keep it stock height or higher, wat 4x4's were meant for.
if i wanted to lift then i would have done it.
but i do not want to lift it.......
so ...
i asked a question and u r not helping.
i dont need ur .02 cents
yeah what GMracer said you can do. the rear of a 4x4 truck is the same as a 2wd truck, so you could add hangers, or put in stock shackles and do a flip kit.
for the front DJM makes 3" lowering LCAs (which is what I will be installing on mine shortly). you could also do 2" spindles up front, or you could get some lowering torsion keys which will probably get you 3" up front.
i personally plan to do a flip kit in the rear and on the front i will be installing the DJM arms, and possibly installing drop keys as well in order to get the front as low as the rear.
this is just what i was looking for. i just droped my 4x4 gm and i to want to go lower lower is beter for these trucks they arnt biult for the mud i was allwase braking ****.
so lower is beter.
how mutch for those drop arms? there the same as the 2x4 right?. i think ill go that way.
so lower is beter.
