Just Bought My 2in Rear Drop
Old 12-20-2004, 11:57 AM
  #31
STOCK_SUCKS's Avatar
Originally Posted by smooth sierra
that would be called a 'carrier bearing' for future use. and it should not be adjusted as it is made to line up with the output shaft of the transmission. If you drop the rear far enough you should shim the rear axle with wedges to compensate for pinion angle. you DO NOT adjust the bearing.
SORRY I WAS JUST GOING BY WHAT THE GUY AT BELLTECH TOLD ME TO DO.THANKS FOR THE ADVICE.
Old 12-20-2004, 12:29 PM
  #32
Banned
CAMMIN03''s Avatar
Will I have to shim the rear end with only a 2in drop.......I really dont want to do that?? And cant you just use the stock bolts for the new shackles. Oh and I dont have a cutting torch... I think Im just going to take the hitch off.......thanks
Old 12-20-2004, 01:48 PM
  #33
smooth sierra's Avatar
no. you shouldn't have pinion angle problems until you get to 4". sounds like you are on the right track. get to wrenching.
Old 12-20-2004, 08:03 PM
  #34
Banned
CAMMIN03''s Avatar
Did the drop today... well took about 3 hours... but.... Its great looking now.... Had a problem with the top shackle bolts.... Had to keep jacking the car and lowering it to get the leaf springs above the frame to get the bolt out... but its done now and I think it looks pretty good.....
  #35
Banned
CAMMIN03''s Avatar
Plus we had no idea what we were doing!!
Old 12-21-2004, 06:23 AM
  #36
congrats! I hope it didn't involve a torch or big ****** hammer at any point. next time you will be faster! 3 hours is not all that bad. I am sure some of that time was scratching the ole head and then figuring something else. lets see some pics!
DarkhorSe_SS
08-20-2015 08:58 AM
bbowerman
07-26-2015 10:57 PM
04450r
07-24-2015 01:58 AM
08nali
07-23-2015 11:39 PM
Quick Reply: Just Bought My 2in Rear Drop
