Which LEDs?
Which LEDs?
Ok fellas I've been looking to replace my interior lights, due to some burning out etc. My question is what LEDs do I need and how many? I've been to superbrightleds.com and can't find what I need. My truck is a 00, and I need the floor lights, gauges, and headliner light. Thank guys.
i dont mean to jack ur thread but im in need of interior LED's also, but i want them just for looks i want to change mine to blue from stock, i need to change all of them, my two dome lights, headliner and also the ones in my gauges, also how to changes the ones in the gauges???
-Rob
-Rob
-Rob
-Rob
I used these...
They are from SUperbrightled.com
921-x12 Wedge Base LED bulb
921 Type with 12 LEDs, replaces 194/168/912 wedge base car bulbs
Wide 75 degree beam pattern, non-polarized
measures 1.20 inch long by 0.60 inch diameter
Gauges... i used these
Need to get some twistlok holders also... your factory ones are a 1 peice design
WLED 4-LED bulb
12VDC 4-LED Wedge Base Bulb (194/168 type)
Polarized
Available in White, Blue, Green, Red, Amber and UV-BlackLight LED
Blue is what i used and its nice...
Sorry... I only have videos of my inside...
headliner i used this one...
4410 LED Festoon bulb
44x10mm (1.732 inches long)12 VDC Festoon Base Bulb with 9 LEDS
Select LED Color
And if your interested in doin the lights in your doors... check these out..
You have to get a small file to round the holes out for the bulb to fit.. but it makes everything flow together..... also get 2 extra if you have Map Reading Lights...
WLED 1-LED bulb
12VDC 1-LED Wedge Base Bulb (194/168 type)with Wide Viewing Angle Available in White, Blue, Green, Red, Amber, Violet and UV-BlackLight LED
PM me if you need help...
carid
10-01-2015 09:22 AM
