Lets see some FUEL CELLS
Old 08-15-2011 | 11:11 AM
chevrolade's Avatar
yea im gonna go straight up to the bed floor..
Hey Stewart what cold air is that?
Old 08-15-2011 | 11:12 AM
TXsilverado's Avatar
UPD.
asl;dkfjasdl;fjkasl;dfjka
chevrolade's Avatar
heres Skeets done by DB Rods
Old 08-15-2011 | 11:15 AM
black04's Avatar
Originally Posted by chevrolade
this is the one i recently purchased ....
RCI 19 gallon ,has the perfect measurements i need 12x12x30...
going to fab it up to where it can retain my oem pump
one question though u see the 3 8an outlets,do i just plug those or atleast put a rollover vent on one?
Is that fuel cell sumped?
Old 08-15-2011 | 11:16 AM
sureshot's Avatar
Originally Posted by black04
Made by NoTwotheSame on here.
Nice looking setup! What size feed line is that? -6AN return?
Old 08-15-2011 | 11:18 AM
chevrolade's Avatar
nope,figured i didnt need it sumped since im gonna use the oem pump
black04's Avatar
Its a -10 feed and yes -6 return. The return fitting on the cell is -8 but I had extra -6 hose so i just used a reduce fitting. Its way overkill for my truck anyways.
Old 08-15-2011 | 11:22 AM
black04's Avatar
I just figure if you're going through the trouble of getting a fuel cell you may as well get a big fuel pump. Or at least have it set up for a good pump for the future like spoolins.
Old 08-15-2011 | 11:26 AM
chevrolade's Avatar
yea i was thinking maybe if i ever need it,may just get one welded in
Competition Engineering 4041 - Competition Engineering Fuel Tank Sump Kits - Overview - SummitRacing.com
Old 08-15-2011 | 11:36 AM
black04's Avatar
Yeah I guess you could get it welded in but you're going to be over 300 into a fuel cell that you still have to mod and weld to get it to fit and work with your stock pump and sender. Or you could get NoTwoTheSame on here to make you one for $375 that bolts right up to the frame where the hitch bolts to and accepts your stock sending unit if you want to run stock pump
Quick Reply: Lets see some FUEL CELLS
