Lets see some FUEL CELLS
Old 08-15-2011 | 01:29 PM
  #21
chevrolade's Avatar
Originally Posted by black04
Yeah I guess you could get it welded in but you're going to be over 300 into a fuel cell that you still have to mod and weld to get it to fit and work with your stock pump and sender. Or you could get NoTwoTheSame on here to make you one for $375 that bolts right up to the frame where the hitch bolts to and accepts your stock sending unit if you want to run stock pump
i got this New RCI cell at a great price ,alot cheaper than the 275 from summit...you have a point though wish i would have know about that guy.u got his contact info anyways?
Old 08-15-2011 | 01:53 PM
  #22
RoadKill03's Avatar
Originally Posted by chevrolade
heres Skeets done by DB Rods
I like this one, how could i get a hold of the guy that did this fuel cell for skeet? i want one for my truck
Old 08-15-2011 | 02:26 PM
  #23
black04's Avatar
NoTwoTheSame on here or you can email him at midnite_kreations02@yahoo.com
You have to pm DBrods on here or email him bagdxtreme@yahoo.com
I got a quote of about 620 shipped from him when I was looking around for the bolt-in/sumped deal.
Old 08-15-2011 | 05:28 PM
  #24
chevrolade's Avatar
thanks for the info.....thats why i figured if i went this route i wont go over 300 bucks
Old 08-15-2011 | 05:55 PM
  #25
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
why no one using PLASTIC tanks? i'm about to do a cell but most likely going plastic
Old 08-15-2011 | 05:59 PM
  #26
chevrolade's Avatar
they flex from heat and start looking ugly after a while.well atleast the ones i seen
Old 08-16-2011 | 07:09 AM
  #27
Spoolin's Avatar
GFYS and STFU
If you get a custom one made ask to have it baffled as well and also put a bung down in the sump so you can drain the tank easily if need be!
Glad you found my tank, it was done by member Vicalma on here as well although I really like black04's too!!
Old 08-16-2011 | 08:20 PM
  #28
BigKID's Avatar
For those of you that removed the rear most crossbrace, are you running bumpers or rollpans? I am just curious about frame flex from the rear leafspring mounts. If running a rollpan, you think the fuel cell is strong enough to provide the needed rigidity in that area?
Old 08-16-2011 | 08:50 PM
  #29
chevrolade's Avatar
ok cool ill keep that in mind...
i removed mine a while back...im running the bumper still...there is no frame flex at all since it has the shock rebar as well.....the spear tire one is thin metal not strong at all
Old 08-17-2011 | 08:46 PM
  #30
454navyss's Avatar
Made by NoTwotheSame on here.
how many gallons does that tank hold? Im seriously thinking about investing in one of these very soon
Quick Reply: Lets see some FUEL CELLS
