Lets see some FUEL CELLS
Old 08-27-2011 | 04:06 PM
  #41
chevrolade's Avatar
Originally Posted by Spoolin
Heavy duty paint stripper works but I had some good luck with just using plain ol gasoline and a scrapper. I know some people have used Brake cleaner but that is expensive.
dude i used that break cleaner,oven cleaner,degreaser,paintstripper,,,i think i burned more brain cells than removing the factory coating lol but most of its off....
Cell swap all done......no CNC machine here, all hand fabbed rings to hold on the oem pump .....
again thanks to u and everyone else who gave some tips and info on this thread.
Old 08-27-2011 | 06:16 PM
  #42
skolman91's Avatar
All that work, and you finish it off by splicing in rubber fuel line with hose clamps. Really..??
Old 08-27-2011 | 11:36 PM
  #43
chevrolade's Avatar
hey it works.high pressure fuel injection hose..but what would u suggest..i can always upgrade later
Old 08-28-2011 | 12:39 AM
  #44
10 Second Truck Club
looks real good zach,u made me think now that i would really like a fuel cell for my next project
Old 08-28-2011 | 01:46 PM
  #45
chevrolade's Avatar
thanks homie....total spent about 350....
rear view
Old 08-30-2011 | 08:42 PM
  #46
Superado's Avatar
11 Second Truck Club
Do these tanks have to be coated on the inside?
Old 08-30-2011 | 09:14 PM
  #47
chevrolade's Avatar
hope not,mine wasnt
Old 09-02-2011 | 04:32 PM
  #48
Superado's Avatar
Originally Posted by black04
Yeah I guess you could get it welded in but you're going to be over 300 into a fuel cell that you still have to mod and weld to get it to fit and work with your stock pump and sender. Or you could get NoTwoTheSame on here to make you one for $375 that bolts right up to the frame where the hitch bolts to and accepts your stock sending unit if you want to run stock pump
If I run one of the ones like yours with a similar pump, feed and return lines, etc...can you still use the stock pump assy for the level sender AND if so, is it fairly accurate?
What did all you guys do about the evap system?
I didn't see any mention of it.
Thanks!
Old 09-02-2011 | 05:31 PM
  #49
chevrolade's Avatar
Thanks!
is the evap system that black box with some hoses going to it?if so i just extended the hose from it and still ran it into the pump...if i can delete that i would?
Old 09-02-2011 | 05:46 PM
  #50
Superado's Avatar
yeah, that's it...thanks.
how about the question about the level sender?
Black04...
I don't see provisions on your tank for a filler neck.
Also, what is the fitting(s) on your tank where all the green tape is?
Quick Reply: Lets see some FUEL CELLS
