Lightweight 20's
Old 11-05-2008 | 12:34 AM
  #21
TouchOfEvil04's Avatar
Originally Posted by SlvrSierra4.8
Anybody have the weight of the 20x8 Stingray III? I have heard anywhere from 19-22 lbs. Anybody weighed one and have the actual weight?
Stingray III weigh 24lbs. I have a set.
Old 11-05-2008 | 12:35 AM
  #22
Originally Posted by 94TRANS
centerlines or also eagle alloys are light to.
i run the 20" Eagle 219's and they are pretty light even with tires.
my 20's with tires weigh about the same as a stock 17" or 18" wheel with no tire.
Eagle Alloy are not a true forged rim and weigh more. I believe they weigh in at around 32-34lbs per rim for the average eagle alloy.
Old 11-05-2008 | 06:59 AM
  #23
SlvrSierra4.8's Avatar
Are you running the 20x8" or the 20x8.5"?
Old 11-05-2008 | 08:34 AM
  #24
StrokerAce03's Avatar
That's the 20x8's.
Old 11-05-2008 | 09:23 AM
  #25
i'm running the 20x8"
Old 11-05-2008 | 09:42 AM
  #26
Originally Posted by StrokerAce03
That's the 20x8's.
When I spoke to Centerline 2 days ago they said that the 20x8.5's were 24-25 lb. and that the 20x8 "ultra light" were 21-22 lb. I wish they could tell me a factual number and not what they think they are..... just trying to save as much weight as possible on the wheel since I will gaining most of it back w/ the tire.
Old 11-05-2008 | 03:58 PM
  #27
well in the end the 20x8 will be lighter regardless of the end weight. Less rim = less weight.
Old 11-05-2008 | 04:27 PM
  #28
skinbrain's Avatar
my Intro's weighed 29-30lbs in a 20x10, i never weighed the fronts 20x9 but i'm sure they are a lb. or two less.
Old 11-05-2008 | 04:38 PM
  #29
On centerlines site if you look up the weights it gives you the 20x8.5 and it's 24lbs.
They don't mention 20x8.0 BUT they give the weight of the 18x8.0 and it's 22lbs.
So i really doubt a 20x8.0 vs a 20x8.5 is gonna be much. A pound at best would be my guess.
Also like i said i have the 20x8.0 and they did/do weigh 24lbs.
Old 11-05-2008 | 07:38 PM
  #30
Cuerva's Avatar
11 Second Truck Club
The 20x8.5 Singrays Ultralight's I sent back were 24lbs, well at least the one I put on the scale. I was considering ordering the Tomahawk Stingray III's 20x8.5 but on a 6" b/s for around $1280. They said those are around 28lbs cause they are a stronger/thiker forge and fully finished. Bad thing is that they're not in stock and have to wait another 3-4 weeks to be made, which from my 1st experience turned to 8 weeks.
Quick Reply: Lightweight 20's
