Lowered on 22s????
Old 02-12-2020, 08:11 PM
  #31
Registered User
D.J. McClain's Avatar
Originally Posted by 1bad2k
My truck has 2'' drop spindles and the belltech 4" drop leaf spring. 22x10" wheels with 305/40/22. No rubbing issues at all.
did you have to have a notch??
Old 02-13-2020, 01:41 PM
  #32
stroker87's Avatar
you can get away with out notching the frame but it will bottom out at 4" on a decent bump and smaller bumps if you haul/tow something, if your not going to notch take off the stock bump stops and install the small button head type
some are ok with this some are not its all about what your willing to put up with, i just notch
Old 03-03-2020, 06:36 PM
  #33
matslp488's Avatar
NBS 4-6 on 22s
Old 03-12-2020, 07:50 PM
  #34
Registered User
owens2380's Avatar
does matter if you running on 20"
Old 05-04-2020, 01:02 AM
  #35
chris99gmc's Avatar
Default This thread is a walking zombie back from the dead LOL!
22x9.5 et 18 on 275/35r22 front and 285/35r22 rear. These tires run on the large side. I’ve had 4 sets of 22’s on two different lowered nbs Sierras.. probably had over 20 different sets of 22” tires over the years. So if you need any suggestions on what fits, just ask. This picture is On coilovers. Tape measure says it’s about a 4.5” / 7” drop. This setup needs a good amount of fender massaging and centering the axle under the bed perfectly. The rear fender lips rub the sidewalls of the tires when I have over 2000 lbs in the bed and the helper bags are struggling. Front fenders have the outer portion of the wheel wells cut out and the fender lips rolled and pulled out slightly. If you dont do anything with the front fenders, it will rub with the offset & width I have. You can’t notice the fender work just by looking at it. But people do notice the bigger tires. .
Did I mention the 285/35 rides far better than a 265/35?
Old 04-23-2021, 07:31 PM
  #36
Tristan Arnar Beck's Avatar
Originally Posted by Last Call
3/5 drop with 285/35R22's.
DJM LCA's and shackle/hanger with no overload.
Attachment 143121
Attachment 143122
sorry for replying to a thread from 2011 but i cant seem to find out how to message you. what is the offset on those wheels?
Old 05-09-2021, 08:22 PM
  #37
Registered User
Richie Hernandez's Avatar
Originally Posted by MikeD.
4/7 Belltech 265/35-22
what is the part number of the kit you get for the 4/7 looks clean and I need it😁
Old 10-24-2021, 10:18 AM
  #38
BIGMerle's Avatar
Bringing this back to life for a noob Just picked up my 06 rcsb and wondering what’s the lowest I can go without messing with any mods on 22x9.5s? What offset do you recommend and tires size?
Old 10-24-2021, 10:44 AM
  #39
matslp488's Avatar
I’m at 4-7 also I got 265 35 22 on front and 275 35 22 zero rubbing
The following 2 users liked this post by matslp488:
BIGMerle (10-24-2021), someotherguy (10-27-2021)
Old 10-24-2021, 11:46 AM
  #40
BIGMerle's Avatar
who did you use for your lowering kit?
Quick Reply: Lowered on 22s????
