Lowered long bed question.
Old 03-14-2008 | 09:01 PM
sv650lex's Avatar
Default Lowered long bed question.
I have a 03 rclb with a 3/4 drop. My problem is when I put 700lbs or more in the back my frame rest on the axle. I have my bump stops cut down to nothing and it still hits. My biggest problem is I want the back a little lower to level the truck out. What kind of drops are you other long bed guys running? Did you have to do a C-notch?
Old 03-14-2008 | 11:08 PM
SBTork's Avatar
You could be just fine with a set of helper bags. I also think that if you were to go lower than 4" in the rear you would NEED a notch.
I just have 2" shackles and want to go another 2 in the rear and 2 up front, I plan on enlisting the help of some helper bags.
Old 03-15-2008 | 04:01 AM
viciousknid's Avatar
Where's the Beef?
I think DozerDan still has some Helper bags for sale that just need new lines. That'll solve your problem. Or you could trade me your drop for my factory suspension.
Old 03-15-2008 | 08:12 AM
outlawz2004's Avatar
I had a 3/5 drop, it rode on the bumpstops all the time. Then I raised it up one inch in the rear, only hit on hard bumps or when loaded. You really need a notch. The helper bags may work, but the notch is the answer.
Old 03-15-2008 | 09:39 AM
sv650lex's Avatar
Yeah I think I should go with the notch and then 1" lower also. Were is a good place to get one? and should I go bolt in or weld in?
mhorn0817
03-06-2016 09:00 PM
maxspeed05V
11-11-2015 05:20 PM
Verz
08-21-2015 07:40 PM
Shtbox
08-02-2015 11:52 PM
Quick Reply: Lowered long bed question.
