lowered Z71
#22
Originally Posted by BigCountryx
Z71 doesn't even add a block, all 4x4's have that. It's basically a shock and sticker package on the trucks. (Hoes are a different story) They may add a crappy skid plate to it also, but it only adds a couple hundred to the sticker and probably is negladgable once a price is negotiated.
There are usually more Z71's to choose from on the lot, so you are more likely to find all of the accessories you want in one wearing the badges.
#23
keys
the leaf springs are made by beltech and it is a little rough drive down the road and the key are maxed out that as low as i can go with keysand the front rides about the same as stock. the keys just lift or lower ur front by turning the torison bars. it might be a waste of a z71 but its what i wanted and im not going to lift it, i like lowered z71
#25
Interesting set up...4" springs and keys. You must have the keys pretty much maxed out huh? How's the ride quality? Did you have to change the shocks and shim the rear? (Sorry about all of the questions...I have a budget 3/4 drop and I really like your truck's stance )
the ride is rough but not 2 bad, ya the keys r maxed out. i havn't changed the shocks yet but i will and i didnt hav to shim it because the leaf spring are pretty flat so it lined up really good
#26
Originally Posted by 64 comet afx
whose leafs are they, Hotchkiss? They always claim that they can't be used on the 4x4's, but the part# on the oem springs are the same whether it 2wd or 4wd. I have been meaning to pick up a set irregardless of what is said
BCraven1018
11-02-2015 07:18 AM
lxcoupe
09-23-2015 12:11 AM
