my 06 silverado
Thanks guys! i have not had it at the track with this setup! but i think it will run high 13s or low 14s cause our elevation is so high! at the track we are at 3600 and with our crappy air over here it puts us around 5800 ft!
Thanks guys! i wanna lower it but not really sure how i should do it! because i cant put hangers on cause they are welded on cause of the shorter bed! it has torsion bars so i can put spindles in the front! but not sure what to do in the back! i already lowered it 4 inches in the back and 2 in the front! it had 2 inch blocks in the back that i took off and i put on drop shackles!
I have same truck, my hangers had rivits haolding them on. Had to grind, and pound them off! It was a PITA! But they came off. I did 2.5" lowering springs up front, and 4" hangers N shackles out back! I'll see if I can find a pic. Did you install your heads? What head gaskets did you use?
