Nissan Titan Rims on GM Trucks? Help
Old 03-19-2011 | 09:17 PM
trucky's Avatar
Question Nissan Titan Rims on GM Trucks? Help
I got offered these wheels at a very good price
I wanted to swap them to my 03 GMC sierra just to give it another look.
I went around and made a small research on them. and found these...
Well, the Bolt Pattern both match(pinkish portion), the stud size and center bore don't.
The Titan's center bore is a bit smaller. My question is: will they still mount on my truck or do I have to make the center bore a bit bigger? If I do, will the original center cap from the Titan's rims still fit?
I've seen many trucks doing it on their trucks, but just don't know how.
Any help is appreciated!
Old 03-19-2011 | 09:22 PM
gs7793's Avatar
i dont think ive ever seen those wheels on a silverado....
Old 03-19-2011 | 09:39 PM
grey matter 04's Avatar
13 Second Truck Club
I ran these titans
Same bolt pattern so it deffinately fits
Old 03-19-2011 | 09:43 PM
trucky's Avatar
Originally Posted by grey matter 04
I ran these titans
Speechless, looks very good with your truck, btw thanks for your help. Did you had any problems with the center bore?
Old 03-19-2011 | 09:45 PM
no center bore was fine
a lil tight but they fit great
just clean the rust off the axle with a wire wheel or brush and they will slip on
Old 03-19-2011 | 09:51 PM
trucky's Avatar
Pretty cool man, I might be getting the wheels this coming week.
What tire size are you running?
Old 03-19-2011 | 09:52 PM
00ChevyScott's Avatar
Wearin' da big hat
I've noticed on mine that the front wheels tend to fit rather snug. It's not the inner bore that is the problem, but more the size of the studs. I can hear the wheel being pushed in further when tightening down the wheels up front, and sometimes getting them off the front hubs can be a chore. They do fit, but not near as well as factory GM wheels designed for the larger sized studs.
After having these Titan 18s, I'll never want to own anything larger or have tires with a lower profile. They ride like *** IMO, but I guess it could be because I've never had a decent set of tires on these wheels.
Old 03-19-2011 | 09:54 PM
BigDawgChevy's Avatar
They will fit and here is a picture of Shanes SS with them on as winter wheels.
Old 03-19-2011 | 09:55 PM
295/45/18 nitto 555s
There to damn expensive
Old 03-19-2011 | 10:10 PM
trucky's Avatar
Have you had any problems at high speeds?
Thanks, they look great, might powdercoat them if I get them.
They are but they give it a nice sporty look, I'm running nitto nt450 on my stock 17s and theyre too expensive
Quick Reply: Nissan Titan Rims on GM Trucks? Help
