OEM or Aftermarket Foglights?
Old 06-15-2005, 03:05 PM
wes00silverado's Avatar
Default OEM or Aftermarket Foglights?
My truck didn't come with the foglights on it and I really want some. So should I go with the OEM or Aftermarket Foglights and why? And can I get green tinted bulbs for them
Old 06-15-2005, 03:52 PM
00z71sierra's Avatar
I'd go with aftermarket. The factory one's pretty much suck; they vibrate a lot and the light output is horrible. You'd be better off getting a nice set of PIAAs or something like that which also includes the harness already. You can swap out to green bulbs but I think it would severely affect light output negatively.
Old 06-15-2005, 03:59 PM
How do I change this text
Wilde Racing's Avatar
I'll second the fact the OEM fog light suck, better than nothing.
Old 06-15-2005, 04:00 PM
BigKID's Avatar
I also say aftermarket. I originally had factory fogs till I melted them with some different bulbs. I then got some Hella FF75 which had great light output and fit well in the inner tow hook openings. Only problem was they had a glass lens that got broke/cracked very easily from road debris. This may not be as bad of a problem for you since your truck isn't lowerd. I would definately suggest looking into something with a polycarbonate lens though.
Old 06-15-2005, 05:25 PM
Gran Patron's Avatar
Ney to the aftermarket!!! OEM the best looking fog lights. I installed them on my 01 truck cant complain. Ok lighting tough. I never had any problems with mine.
Old 06-15-2005, 05:32 PM
SS Crew's Avatar
I've got at set of OEM fog lights that I pulled out of my truck when I put the SS facia on mine. I only have the lights, the wiring, switch and everything else is in the truck and is staying there. If you want them PM me.
Old 06-15-2005, 10:16 PM
Which fog lights fill up the gap the best? I kinda want one big enough to fill the whole thing up. Also does anyone know off hand what the deminsions are on the fog light or tow hook holes in the bumper?
Old 06-15-2005, 11:10 PM
Searching4Sierra's Avatar
i'd go with oem, they look the best. and with your lower fascia you can run 4 fog lights if you really wanted to
Old 06-15-2005, 11:49 PM
PT's Slowest Truck
budhayes3's Avatar
The OEM's work fine for me...fill the hole perfectly too. (mine came with em from the factory)
Old 06-16-2005, 08:32 AM
I think the OEM fog lights are the ones that fill up the gap the best I have thinking about this for a while and I decided I am going with OEM Fog lights....
Quick Reply: OEM or Aftermarket Foglights?
