over head console/gauge mounting questions
Old 01-25-2011 | 06:30 PM
Steve-O-08's Avatar
Default over head console/gauge mounting questions
First. Has anyone ever used an overhead gauge pod to mount their gauges? I've been searching and haven't found anything. Autometer makes a dual and triple mount that goes just above the rear view mirror. I wanted to know how they are secured.
Also thinking about mounting them in an overhead console, which leads to my second question...
Does anyone have a write up on installing an overhead console in a truck that didn't come with one? I like the look of putting them in a factory console but want to make sure one will work in a truck not equiped with one.
Old 01-25-2011 | 06:49 PM
OL' MAN's Avatar
Check socaldiesel.com. I've got my wideband and boost mounted in one of their pods.
Old 01-25-2011 | 08:42 PM
blue0453's Avatar
I made this one out of 1/4 mdf and 2 1/16 gauge shades truned around backwards.
Attached Thumbnails over head console/gauge mounting questions-june202010-035.jpg
Old 01-26-2011 | 11:59 AM
Steve-O-08's Avatar
Looks good. I did see the socal mounts and they look nice. Would probable end up making my own to fit in there. Anyone installed an overhead console in a truck than didn't come with one?
Old 01-26-2011 | 08:34 PM
blue0453's Avatar
It shouldnt be too hard, theres only one screw and I think like two little prongs that hold the thing in place.
Old 01-26-2011 | 08:39 PM
2007chevy5.3l's Avatar
Old 01-26-2011 | 09:18 PM
VTJosh's Avatar
My 2000 ECSB didn't come with one but I managed to pick up one of the longer overhead console's from a junkyard. I just mocked it up to where it goes to get my reference points on where to cut through the headliner. The rear just slides into a recess and the front part bolts in. I tapped into the postive wire from the dome light and ran it above the headliner to the positive wire on the maplights and I grounded out the negative up by the front mounting points. My console is blank up front where I believe the rear HVAC controls typically go. Regular cab trucks may not have the recesses for the console though.
Old 01-26-2011 | 09:29 PM
Bigredmariner's Avatar
I used the SoCal diesel panel, it's a nice piece but it comes with no hardware. I had to make a couple of brackets and get some 1/4-20 bolts, no big deal but you would figure for $125 they would include $2.00 worth of mounting hardware.
Old 01-27-2011 | 07:40 PM
Steve-O-08's Avatar
Anyone else with an overhead gauge pod not in the overhead console?
D1SCSS
01-25-2016 10:14 PM
BennyB
08-01-2015 08:48 AM
USMCvet0311
08-01-2015 07:45 AM
bbowerman
07-26-2015 10:57 PM
Quick Reply: over head console/gauge mounting questions
