P-i-t-a
#43
Resident Retard
Truck sounded good man, but work on those issues i told you about... Then contact a different tuner...
Hmmm, well the tune has some issues... I am not sure what the background is of the tuner but let me see if yall see an issue with the log... Here is a couple of screen shots of a long WOT pull... This is one of the first times out of all the trucks that i have looked at and said, "DO NOT got WOT until you get a new tune/tuner"....
Sorry for the bad news man, but i said i would give you my no BS opinion....
#44
^^thanks for helping me out corey. i knew the truck wasnt running right...
to everyone- DO NOT use High Stakes Racing in Rowlett. as you can see, they aren't the best tuners. The guy hasnt answered my calls or returned my texts or voicemails. The way i see it, i wasted $250
but thanks for being completely honest with me corey, i'd much rather someone give me the whole truth no matter how bad it is vs someone beating around the bush saying it may be bad and then me go screw it up cause the tuning is so bad....and i'll get those smaller things fixed that we talked about.
and now everyone hangs out at the starbucks....and due to my horrible tuning, i wont be doing any racing but i'll still be out there
#45
11 Second Truck Club
Alright cool. Me and my bro used to take his gsx eclipse out there and then go to the airport and race. It was a ricer but was mo bad. Puttin down a lil over 400 at the wheels
#47
for sure man....corey said theres a little left in the truck, so hopefully there'll be a noticable difference when i get a better tune other than it just running cleaner in general
#50
Resident Retard
The point of those screen shots are to show that the truck never entered open loop/PE mode. so his AFR never goes richer than 14.68, because the tuner did not lower the PE delays (which is pretty much standard on creating a tune).... LTFT were still active at WOT which should not happen... also his LTFTs at part throttle are pretty far off, which means it needs some airflow table corrections.... the reason he should not go WOT is because of the insane lean condition.... if he continues going wot he will burn up that motor... the shitty thing about all of this is that he would have never know unless i logged it...
